particle system driving fluid???
COW Forums : Autodesk Maya
Neil Wilson
on Jun 27, 2008 at 9:46:23 am
Is it possible to make particles emit fluid inside a fluid container?
I know you can make particles follow a fluid but I really need the opposite for this - and cant seem to get the connections right. I tried instanced geometry as emitters but it wont connect.
Steve Sayer
Re: particle system driving fluid???
on Jun 27, 2008 at 2:33:40 pm
I don't know anything about fluids, as I only have Maya Complete. But there's a tool called Afterburn or Overburn that you might want to look into... I think I recall that it does a lot of work mixing effects between particles and fluids.
-Steve
Alvaro Castaneda
on Jun 29, 2008 at 6:44:08 am
Hi
I don't have maya here but I think it can be done, you might wanna try instancing fluid emitter to the particles, but emitting fluid from particles might not be a good idea.
I'll try it at work
varomix - pixelEater
http://www.intelianimate.com
