animate arrow
COW Forums : Autodesk Maya
ashley ying
animate arrow
on Jun 14, 2008 at 5:08:23 pm
helloo
ashley here
actually i have problems when doing this animating tutorial
i refer it from sketchy's http://sketchypictures.com/tutorials/maya/animated_arrows/arrows.html
but thing is... i encounter alot of problems....
- after the arrow is animated, can i edit the control vertex to give the correct shape?
- the curve should have alot of vertexes?
- after animating the curve.. i have problems when i want to make the surfaces smooth...
-i thought of clicking `rebuild surfaces` instead of the tessellations.. but it jerked up when it animated.
-and even if i choose to click the tessellations... i sense some parts of the curve got jerk also ( this happens when i edit the curve after animating the arrow.)
... i already mailed him aboutt he same qns.. but maybe you guys know how to?..
i'm a slow learner thats why i get so confuse easily..
sory for asking so much questions and mind my bad english
i really appreciate your guys help to reply my problem
p.s im using MAYA 8.5
best regards from
ashley
Alvaro Castaneda
Re: animate arrow
on Jun 15, 2008 at 7:23:23 pm
hi ashley
yes absolutely, just try to keep it centered
- the curve should have a lot of vertexes?
I suggest that you have enough to make it as smooth as you like
just follow the tutorial, the tessellation attributes only affect the surface at render time, that's why you have to turn on the RENDER TESSELLATION flag on so you can visualize how it will look at render time, try a test render and your surface will look nice
yeah, if you wanna do that, rebuild THE CURVE, the surface is based on the division of the curve, that will make it smoother, but, tessellation work great also, use what ever works best for you.
ok
l8r
varomix - pixelEater
http://www.intelianimate.com
