rendering multi image planes
COW Forums : Autodesk Maya
Jim Medcraft
on Jun 7, 2008 at 4:52:12 pm
I have 2 image planes with image sequences on them and i want to render out, problem is that only one will render out on each respective camera, help?? I need one of the planes to move with 3d model and I was annimating the camera to move with it it seems to be fine help please????????
Alvaro Castaneda
Re: rendering multi image planes
on Jun 9, 2008 at 1:21:40 am
Hi
I don't think you can actually render both image planes, you can add one of those to a plane object and parent it to the camera if you need to, the other one might be an actual image plane on the camera.
I don't know what you are doing or need to do but this might be easier to do in compositing.
good luck
varomix - pixelEater
http://www.intelianimate.com
leigh wells
on Dec 22, 2009 at 10:13:30 am
I'm working on a similar project. Let me know if you get the problem solved. Thanks!
