Photoshop File on a polygon
COW Forums : Autodesk Maya
Karen Kent
on Jun 5, 2008 at 2:59:04 pm
I have a basic polygon rectangle that I want to put a photoshop file on just the front face. I know this is simple, but I can't figure this out for the life of me. When I apply the texture, I shows the letters of the file very small & there are about 50 groups of the text. How do I fix this?
Karen
Karen Kent
Re: Photoshop File on a polygon
on Jun 5, 2008 at 3:27:45 pm
Never mind - I FINALLY got it!
Karen Kent
Re: Photoshop File on a polygon...Now What???
on Jun 5, 2008 at 4:33:28 pm
OK - so I have my surface on my polygon face. Now I need it to move with my object. I selected the "place3dtexture" node, then selected my poly face face & tried to parent them, but when I do I get the error: not enough objects or values? What do I do now?
Karen
Alexander Venske
on Jun 5, 2008 at 6:21:49 pm
Ola,
As far as my knowledge goes the texture is connected to the object and when moving/translating the object the texture will follow. There should be no reason to parent the one to the other.
Alvaro Castaneda
on Jun 10, 2008 at 9:42:08 pm
HI
I would say you just need to delete history of the object
if you do need the texture to animated etc, just parent it to your object or make a parent constraint.
But I'm almost sure that is you delete history on your object will solve it
(EDIT > DELETE BY TYPE> HISTORY) have the object selected.
varomix - pixelEater
http://www.intelianimate.com
Karen Kent
on Jun 10, 2008 at 9:49:00 pm
That seems to have done it. Many Thanks!
Alvaro Castaneda
on Jun 15, 2008 at 7:28:40 pm
hi
Yeah, never forget the delete the history of objects, when your done modeling or texturing.
Hope that you can share us what you are doing, even your WORK IN PROGRESS (WIP).
thank you
