Camera Projection
COW Forums : Autodesk Maya
Nick Whitlock
Camera Projection
on May 21, 2008 at 9:02:03 pm
I've projected a matte paining I made onto some simple geometry in order to create a 2.5D camera move. I usualy use AE for this but from what I've seen, a 3D package creates a more believable result. The only problem I'm haveing is figuring out how derive the lighting from the painting itself. Without lights, the scene obviously renders black but when I use any type of light the geometry has highlights and shadows creating a really odd result. What am I missing?
Alvaro Castaneda
Re: Camera Projection
on May 29, 2008 at 6:34:30 am
this one is easy, but I've seen different ways to do it, i like this one
create a Lambert material
assign you texture to the color channel
and then this it the trick
put ambient color aaaaaall the way to one
and diffuse all the way to zero
this will make the surface a total replica of your image, also, change the filtering in the image node, I change it from the default Quadratic option to OFF, so guys like to just lower it I just turn it off.
this will work for you, it does for me
good luck
varomix - pixelEater
© 2018 All Rights Reserved
