mental ray batch render errors - university final piece please help
COW Forums : Autodesk Maya
Tom Hunt
on May 20, 2008 at 6:02:08 pm
hiya
ive been having some problem batch rendering in mental ray from maya 8 on an intel 2.16ghz imac with 1.5gb ram.
recently mental ray has become temperamental, sometimes batch rendering and sometimes not. this is the log when i try to bathc render 15 frames. previous to this i have been able to render 210 frames and 100 frames on separate occasions.
Starting "/Applications/Alias/maya8.0/Maya.app/Contents/bin/maya"
mental ray for Maya 8.0
mental ray: version 3.5.1.2, 15 Jun 2006, revision 18552
mental ray: mental ray for Maya - startup done
File read in 0 seconds.
File read in 2 seconds.
File read in 3 seconds.
Warning: This file contains an uncached fluid; rewind and playback to see correct current state.
Result: /Users/tom/Pictures/Art/Motion Graphics/final project/3d models/speaker/speaker final/speaker final 1.mb
mental ray: got 8 satellite CPUs.
Prog: (Mayatomr.Scene) : optimize animation detection: done (129 animated nodes)
MEM 0.0 info : heap size limit set to 1200 MB
Info: (mental ray) : number of render thread(s): 8
Info: (Mayatomr.Nodes) : derive mental ray global approximation settings from Maya
Info: (Mayatomr.Nodes) : derive mental ray global displacement settings from Maya
Info: (Mayatomr.Scene) : update lights and related shaders
Info: (Mayatomr.Scene) : update cameras and related shaders
Info: (Mayatomr.Scene) : update geometry and materials
Prog: (Mayatomr.Scene) : DAG node: nurbsPlane1
Prog: (Mayatomr.Scene) : DAG node: spotLight1:coneShape1
Info: (Mayatomr.Nodes) : spotLightShape1.coneAngle: unsupported type of connection, current plug value used instead
Info: (Mayatomr.Nodes) : spotLightShape1.endDistance3: unsupported type of connection, current plug value used instead
Prog: (Mayatomr.Scene) : DAG node: fluid1
Prog: (Mayatomr.Scene) : DAG node: projector:polySurface13
Prog: (Mayatomr.Scene) : DAG node: projector:projectorLight:projector:coneShape1
API 0.0 error 301090: undefined instance symbol "projector:projectorLight:projector:projectorLightShape"
API 0.0 error 301063: undefined light instance "projector:projectorLight:projector:projectorLightShape"
Info: (Mayatomr.Nodes) : projector:projectorLightShape.coneAngle: unsupported type of connection, current plug value used instead
Info: (Mayatomr.Nodes) : projector:projectorLightShape.endDistance3: unsupported type of connection, current plug value used instead
Prog: (Mayatomr.Scene) : DAG node: speaker:leftLegInfluence
Prog: (Mayatomr.Scene) : DAG node: speaker:rightLegInfluence
Prog: (Mayatomr.Scene) : DAG node: speaker:polySurface16
Error: (Mayatomr) : mental ray has stopped with errors, see the log
Error: Scene /Users/tom/Pictures/Art/Motion Graphics/final project/3d models/vjtv ident/vjtvIdent 2/scene 2/New_Project/masterscene1.mb failed to render.
MSG 0.0 info : wallclock 0:03:08.41 total
MSG 0.0 info : CPU user 0:03:04.09 total
MSG 0.0 info : allocated 1 MB, max resident 5 MB, RSS 0 MB
// Maya exited with status 210
i am guessing it has something to do with the 'undefined instance' errors. the spotlight mentioned is in a file referenced by the scene i am trying to render.
this is for a final project for university and seeing as i have never had this problem before i have no idea how to remedy it
any help would be greatly appreciated
thanks
tom
