Problem making basic selections in MAYA 8.5
COW Forums : Autodesk Maya
sofia tyler
on May 15, 2008 at 1:14:43 pm
Each time I select a face, edge or vertex in MAYA 8.5 it selects an entire region. similar to a grow select, but the selection ranges in color from yellow to orange to red. When I attempt to deform, move / scale etc it effects entire region, not just selected face, as if it were the soft modification tool.
It must be a setting I have clicked without realizing.
I have tried switching on and off everything I can think of ! AT this stage I am considering re-installing entire package !
Any Suggestions welcome !
thanks.
Alvaro Castaneda
Re: Problem making basic selections in MAYA 8.5
on May 29, 2008 at 6:40:54 am
There might maybe a selection constraint active. try this
get into face mode select a face
ctrl+right Click and select in the bottom Selection constraints...
a window will pop up, just click the button labeles Close and Reset,
that will close it and you will get into you normal selection mode.
hope that does it
varomix - pixelEater
