working w music file in maya
COW Forums : Autodesk Maya
steve challa
on May 6, 2008 at 4:53:31 am
Can we import music file to Maya and work with the music to drive animation in Maya. Can any one advice me. Thanks a lot
John David Hutton
Re: working w music file in maya
on May 6, 2008 at 4:27:14 pm
Yes you can. It begins to depend on what sort of music you're using and how you get it into Maya but it's certainly possible (I'm assuming you want an After Effects / Sound keys equivalent for Maya). I suspect it would be easier to pull off in After Effects and render separate layers in Maya to get the animation you're wanting, however.
I typed the following into Google and found these links:
music drive animation maya
http://www.highend3d.com/maya/downloads/plugins/animation/MIDI-Tools-Plug-i...
http://www.cs.ualberta.ca/TechReports/2006/TR06-17/TR06-17.pdf
- MythProd
Mythical Studios
(John David Hutton)
_________________________________________
2D / 3D Motion Graphics Artist, Editor, Support Technician
Kansas City, Kansas - United States
steve challa
on May 15, 2008 at 3:48:34 pm
Dear John
Thank you very much. Hope it's not too late to respond to you.
Are you familiar to HOUDINI ?
I heard it has a tool called "Chops" that allows working with imported music file to drive animation, I am a beginner in 3 D. How do you compare MAYA to Houdini if you know it. Thank you very much in advance.
Steve
John David Hutton
on May 15, 2008 at 4:12:37 pm
I've read about Houdini but hadn't used it before. Maybe someone else will chime in and give their opinion on the program and how it relates to what you're trying to do?
- MythProd
Mythical Studios
(John David Hutton)
