Light fog
COW Forums : Autodesk Maya
Per Spook
Light fog
on Apr 3, 2008 at 2:44:02 pm
Hola!
I'm making a lighthouse. To see the light beam, I'm using a spotlight with the Light fog enabled.
Then i'm rotating the spotlight 360 degrees as a normal lighthouse would work.
The problem is that on the lighthouse there is one wall that is supposed to block of the light beam (towards land), but the light fog goes right through the wall.
Anyone knows how to adjust this?
thanks
Steve Sayer
Re: Light fog
on Apr 16, 2008 at 2:04:01 am
I think I recall that turning on depth map shadows for the light should cause solid objects to block the light cone.
-Steve
jacob windecker
Re: Light fog
on May 13, 2008 at 10:46:31 pm
Have you tried turning on depth map shadows in the light's properties? i made a similar light, but you have to turn on the shadows in the properties for it not to shine through an object.
