moving and bending at an angle
COW Forums : Autodesk Maya
Karen Kent
on Apr 2, 2008 at 2:21:45 pm
I'm trying to animate a printing press - where the paper rolls under rollers, then bends sharply (almost a 90 degree angle) & shoots up in the air. I've tried animating along a path, but the entire paper moves along the path & does not bend. When I use a non-linear bend deformer, it curves upwards, & does not bend at the sharp angle I want it to. Does that make sense? I bet this is really simple, but I can't wrap my head around it. Suggestions, please? Thanks! Karen
Chad Briggs
Re: moving and bending at an angle
on Apr 2, 2008 at 5:22:57 pm
if your paper doesn't have any thickness, look into a birial shape. (i actually have a tutorial on this here on the cow)
http://library.creativecow.net/articles/briggs_chad/maya_ribbon.php
-chad
Karen Kent
on Apr 3, 2008 at 7:54:03 pm
Thanks Chad. I actually saw this yesterday & tied it, but I couldn't get it to work. I'll try it again later. Karen
Frank Rieder
on Oct 5, 2009 at 5:22:26 pm
Karen,
did you ever get this to work.
I am working on a printing press myself and I am stuck
trying to wrap the plate around one of the cylinders.
Any help would be appreciated.
Frank
