isoparms to curves
COW Forums : Autodesk Maya
Ken De Cooman
isoparms to curves
on Mar 27, 2008 at 12:02:38 am
Hello,
maybe a stupid question, but it would help me enormously... Doing a architectural design.
Suppose i have a mountain in 3D. This mountain would have horizontal isoparms. How can I make ring-surfaces of these horizontal isoparms?
I think I can ask my question differently: how do I make a isolated curve that I can work with, from a horizontal isoparm?
Tanx
Ken
Steve Sayer
Re: isoparms to curves
on Mar 28, 2008 at 2:16:46 am
The 'Edit Curves > Duplicate Surface Curves' command should do the trick.
If you don't want to use the actual isoparms of your surface, but want to create your own curve, use a flat plane and the 'Edit Surfaces > Intersect Surfaces' command to create a curve where the plane intersects your mountain. Then 'Duplicate Surface Curves' as above.
Hope that helps.
-Steve
Jason Brummett
on Mar 28, 2008 at 1:24:43 pm
also if you want to have a new circular nurbscurve passed on a grid mountian terrain, create a new circular curve in the top view and projected onto the existing nurbs grid surface and then duplicate curves like Steve suggested.
Jason Brummett
Studio Z Inc.
Ken De Cooman
on Mar 31, 2008 at 8:09:50 pm
ok guys tanx!
it solved my problem. Now I'm on my way :)
Ken
