render's three times
COW Forums : Autodesk Maya
Ian Richards
on Mar 26, 2008 at 1:03:41 am
I have a shot that I am batch rendering in mental ray. The problem is that it renders the shot three times before finishing. It goes through to the last frame and then starts the render again....three times in total. If anyone can help it would be greatly appreciated.
Thanks Ian
Alvaro Castaneda
Re: render's three times
on Mar 29, 2008 at 8:20:07 pm
mmmh, that is wierd
check this few pointers
do you have only ONE renderable camera
do you have diferent render layers
asure that you have set the in and out frames
if you are using the command line declare them there explicit
like this Render -r mr -s 1 -e 300
-s start
-e end
hope that helps
varomix - pixelEater
© 2018 All Rights Reserved
