EP Curve Help!
COW Forums : Autodesk Maya
Emil Tan
EP Curve Help!
on Mar 5, 2008 at 7:55:14 pm
Hi guys, big newbie here,
but quick question...I made an EP curve and duplicated it so that they are next to each other....I need to make another EP curve so it joins them at the ends with a straight line..I want to do this in order to use a birail...I CAN'T GET THAT ONE EP curve to join the 2 orginal Curves....I can't get it to follow along the original curve so that I can make them join at the edge.
Someone please help me out!
Chad Briggs
Re: EP Curve Help!
on Mar 6, 2008 at 1:33:04 am
have you tried these two things?
1.) set the curve to a 1 degree curve in the creation options
2.) hold down the C key to snap the new curve points to the other curves?
-chad
Emil Tan
Re: EP Curve Help!
on Mar 6, 2008 at 8:26:28 am
yes, thank you so much, It was the C Key i was looking for. I knew it was something like that. Thanks a lot dude!
