help!!!!- MAYA to AE
COW Forums : Autodesk Maya
colleen Schwab
on Mar 4, 2008 at 7:07:36 am
Does anybody know how to import a maya animation into AE without a background. Or at least a guide to any good tutorials. I have been trying to do this over two weeks and I am desperate.
Thank you
Chad Briggs
Re: help!!!!- MAYA to AE
on Mar 5, 2008 at 4:37:40 am
So what do you have in maya that is creating the BG? is it a image plane on the camera? or is it objects behind the object of interest?
-chad
Per Spook
on Mar 6, 2008 at 7:52:25 pm
Just render your object(s) out as a targa sequence with an alpha channel, you'll find it in the render settings. remember to set the "frame/animation extension" to "name.#.ext" and the frame padding to 3 if you have more than a hundred frames of animation. Then go to render-batch render. your images will be placed in the directory you specify under file - project.
Hope this helps..
And if you need to bring in your camera to mach up the animation in AE (if the camera has animation of course). select your camera and bake your animation keys, and save the file as a .ma file. Then AE will read it fine.
