Couple of path extrude questions...
COW Forums : Autodesk Maya
James Curran
on Feb 15, 2008 at 10:58:52 am
I'm doing some stuff with animated extruding shapes along paths.
How can a vary the width of the extruded shape along the path? e.g. have it taper or widen as it reaches the end.
Also currently my extruded shapes are just tubes, how can I cap the ends off?
James Curran
Re: Couple of path extrude questions...
on Feb 15, 2008 at 11:32:36 am
Also, at home after i'd done the extrude I could edit settings in the channel box, or modify the original paths to effect the extruded shape. Trying to do it on my work pc now and I dont seem to be able to do any of that. Is there a maya setting somewhere that I need to fix?
James Curran
on Feb 15, 2008 at 11:48:51 am
I figured it all out, nothing to see here!
Thanks anyway :)
