No alpha with Mental Ray dgs_material?
COW Forums : Autodesk Maya
smoobg
on Jan 15, 2008 at 2:43:26 pm
Rendering a dgs_material shader with an mib_reflect node and I can
Alvaro Castaneda
Re: No alpha with Mental Ray dgs_material?
on Jan 15, 2008 at 7:52:40 pm
hi
you can try and make a object matte pass with another render layer, or make a CUSTOM pass where you render something you can key in after effects or any other app, I'll go for the object matte pass.
l8r
varomix - pixelEater
Per Spook
on Jan 23, 2008 at 10:13:31 am
I had the same problem just a few weeks ago, and got the answer from Alvaro Castaneda, here's the solution:
Go to render settings, in the MR setting find the custom entities tab, expanded and check the PASS CUSTOM ALPHA CHANNEL check box, render again and you are done man.
Per Spook
on Jan 23, 2008 at 10:22:32 am
Well, well, that was you already answering Alvaro. Then maybe my tip won't work..
