Maya (Scale/Move/Extrude) issue
COW Forums : Autodesk Maya
MediaMason
on Jan 13, 2008 at 4:10:16 pm
I just made the jump to Maya from 3Ds max and I'm not sure if I changed a setting, every tutorial I've seen shows x/y/z as color boxes or arrows a couple inches away from the center point of an object like this
click here mine are just color lines that run the whole length of my scene/view. I haven't had a real issue until I needed to extrude I don't have the blue dot to center the angle. did I change something that took this view away. Using Maya 7.0 Thanks
Chad Briggs
Re: Maya (Scale/Move/Extrude) issue
on Jan 16, 2008 at 2:23:05 am
try hitting the plus and minus keyes on the keyboard and see if that changes the size of them. If not, it's probably a video card issue.
-chad
MediaMason
on Jan 16, 2008 at 5:34:52 pm
yeah nothing. I have a 256 nvidia 6600 not the best but should work just fine. Thanks anyways
