Downsaving?
COW Forums : Autodesk Maya
Jason Higgs
Downsaving?
on Jan 9, 2008 at 3:40:41 am
Hey Guys,
What is the best way to get a Maya 2008 scene in to Maya 8.5?
My work has 2008 and I have 8.5 at home. I have tried just a simple .mb file with no luck and have yet to try a .ma
Nothing fancy no shading,or textures or lights... Just some modeled nurbs and polygons.
Is there some preference setting I am missing? Is this even possible?
Thank you in advance!
Chad Briggs
Re: Downsaving?
on Jan 11, 2008 at 3:20:10 am
I'm not sure it will work with these versions of maya, but what has worked in earlier versions is to save your file as a maya ascii file. open it up in notepad. At the very top of the file, you'll see a few lines declaring "maya 8.5" or something like that. (there should only be about 3 or 4 entries like that). Change that line to the version # you want to open it in, and it should open in the older version. hope that helps
-chad
Jason Higgs
Re: Downsaving?
on Jan 11, 2008 at 11:59:07 am
Thanks Chad... Worked like a charm!
