Convert instance to geometry
COW Forums : Autodesk Maya
Christopher Flanagan
on Jan 7, 2008 at 8:44:11 pm
You can change an instance into a mesh through
Modify>Convert>Instance to Object
This is in Maya 2008. Though, probably in your case using the instances will actually save CPU power.
