Real-time is 24 fps
COW Forums : Autodesk Maya
Karen Kent
Real-time is 24 fps
on Dec 10, 2007 at 5:03:50 pm
Why is my real-time timeline preference 24 frames per second & not 30?
Pyro
Re: Real-time is 24 fps
by
on Dec 10, 2007 at 5:26:05 pm
Maya defaults to the feature film frame-rate of 24fps.
Unfortunately, I do not know of way to set the default to 30fps permanently.
SSGGMM
on Dec 10, 2007 at 5:33:48 pm
Try: Window > Settings/Preferences > Preferences
Under "Categories" select "Settings"
You can change that frame rate here. It might only work on project-by-project basis, though.
SSGGMM
on Dec 10, 2007 at 5:36:17 pm
Careful: It'll mess up your timeline keys, if any. But I think there's a checkbox for that.
Karen Kent
on Dec 11, 2007 at 2:11:38 pm
That's the first thing I tried, but the only thing I see is in "Timeline>Playback" & there's no 30 fps choice. I checked all the categories under "Settings" & didn't see one for 30 fps. Am I missing something? Thanks for your help!
SSGGMM
on Dec 11, 2007 at 2:52:33 pm
Don't click the categories "under" settings. Click THE WORD "settings" itself.
I know, the layout is misleading. The way it's all set up, you'd think "Settings" is just a heading introducing what's below. It's not. It's a clickable item with its own parameters.
Karen Kent
on Dec 11, 2007 at 2:54:54 pm
Well would you look at that! Thanks VERY much!
