Maya and digital glitch in shaded view - Possible graphics card issue?
COW Forums : Autodesk Maya
graphic43
on Dec 7, 2007 at 5:39:58 am
I'm having a problem with Maya and believe this is caused by my graphics card. Can someone confirm this issue or has anyone seen this before? Is it possible that my graphics card doesn't have enough memory?
Computer setup:
This digital blocking doesn't seem to affect the final render, but is noticed when viewing the basic shaded model. Click on the images below for higher resolution images showing the digital blocking.
Notice the digital glitch blocks on the shaded panel
http://farm3.static.flickr.com/2079/2091092077_de83cacb98_o.jpg
Same digital glitch blocks on the full sized shaded view but not as bad
http://farm3.static.flickr.com/2147/2091876314_e648e61e96_o.jpg
Another screen grab of the digital glitch blocks. These glitch only seems to occur in the shaded view.
http://farm3.static.flickr.com/2126/2092882052_2701cd2573_o.jpg
This has a big red blob in the shaded panel
http://farm3.static.flickr.com/2204/2092881918_3d8f28b4af_o.jpg
Same glitch as above but a different color
http://farm3.static.flickr.com/2384/2092101555_55a6726fcd_o.jpg
Any advice would be much appreciated.
Rob
Alvaro Castaneda
Re: Maya and digital glitch in shaded view - Possible graphics card issue?
on Dec 7, 2007 at 5:28:25 pm
Hi
It a problem with your graphics card, you can try updating your drivers and see if that makes any difference, if you just can't work with that, buy a better card you can get a very decent card for 80 bucks, I recomend the GeForce FX series work very nice and are cheap.
good luck
l8r
varomix
pixelEater
varomix - pixelEater
graphic43
on Dec 7, 2007 at 7:18:06 pm
Thanks for your help and suggestion.
Rob
