Blend Shape Problem :(
COW Forums : Autodesk Maya
Kaja Rachel
on Dec 6, 2007 at 4:18:27 am
Hi all, I just finished modeling all the facial expression blend shapes, and some work fine but others blow up the gometry and completely self destruct and revert when applied.
ive tried deleting hisory and duplicating those objects for the sake of having clean history but it doesnt help.
Any suggestions?
Alvaro Castaneda
Re: Blend Shape Problem :(
on Dec 7, 2007 at 5:42:50 pm
Hi
well, you can delete the NODES in the hypergraph, select your final object, open the hypergraph and hit the INPUT and OUTPUT conections button, sixth button from the left, and there, delete just the nodes you don't need
hope this helps
varomix - pixelEater
