Embedded alpha channel
COW Forums : Autodesk Maya
SSGGMM
on Nov 28, 2007 at 9:10:08 pm
Learning Keylight. The documentation says: "If more than one
mask is required to remove garbage, then use the masks to
create an embedded alpha channel..."
This is from a section on Inside masks. I get the idea, but how do I go about creating an embedded alpha channel? Does it require a render?
Thanks in advance - SGM
SSGGMM
Embedded... (wrong forum - sorry 'bout that)
on Nov 28, 2007 at 9:44:25 pm
