Shader resolution question
COW Forums : Autodesk Maya
on Nov 5, 2007 at 3:08:48 am
Hi all, every time I apply a shader I've made, or one I've downloaded, it totally loses all its resolution and gets blown up and pixelated. For example, I'm trying to create sand but the fractal pattern doesn't stay small and fine. It keeps enlarging when applied to my surface. What am I doing wrong?
Steve Sayer
Re: Shader resolution question
on Nov 5, 2007 at 2:11:46 pm
Are you referring to the appearance in a hardware-textured viewport, or the results of the final render?
If the former, you just need to change the hardware texturing resolution, accessible from the material node. Change it to 'high' or 'highest'.
If the latter, the scale of textures is affected by the parameterization of the surface to which it is applied, and finally controlled by their placement nodes.
For a 2D texture, increase the repeat U and V values. For a 3D texture, increase the scale X, Y, and Z.
© 2018 All Rights Reserved
