Maya problems...please help!
COW Forums : Autodesk Maya
curt1001
on Oct 16, 2007 at 12:42:05 pm
HI,
I am a student based in the UK working on my final project in maya and having some big problems.
I have created a room using maya 7. Everything was working fine until reciently, when I tried to import my jpegs to use as a texture. the polygon cube which I used as the room base keeps deciding to go transparent in my viewport (This actually happens as soon as I press the 'file' button to import on the 'colour' link rather than after the jpeg file has been imported). When it goes transparent, it leaves lines around the cube and verticle lines where the texture should be. If I place a standard texture such as a phong ect on it, it all looks fine.
Would anyone know why this would happen?
Any help would be great!
Curt.
zozoferoce
Re: Maya problems...please help!
on Oct 16, 2007 at 4:58:55 pm
Look in the Shading Panel maybe? Is hardware texturing turned on?
nanda kumar
on Dec 7, 2008 at 5:39:18 pm
hai
this is nanda, i have a big problem in any "maya" software, i formate my system, on that time onwards in maya if i can take any object or character means it cant see move tool, scale tool rotate tool in left, top, front views, but i can see it in prespect views, so many times i can formate my system and change another "xp" but there is no use plz help me anybody, my project works are pending plz try to help me, i am waiting for your reply
akashdeep karmakar
on Mar 2, 2010 at 4:20:52 am
Hi, i m Akashdeep Karmakar. I have a problem in maya software. Problem is that i m not able to see the menu bar. I mean the menu bar of the maya software is not showing. So i really need help. I'll be great full if u please help me.
Thank you
