pixel aspect ratio - SD to HD
COW Forums : Autodesk Maya
on Oct 8, 2007 at 7:27:17 pm
Hey all-
I'm pulling out an older project that a client wants changed from SD to HD.
I want my framing to be exactly what was in SD plus extra content on the left and right- imagine going from a 720x540 frame to a 960x540 frame.
The problem that I am having is that whenever I change the render settings to a different aspect ratio or pixel width/height, the renderable area of the frame converts to HD (16:9) by a reduction in height instead of an addition in width. The 720x540 frame essentially turns to 720x405.
My camera is animated, so I am not going to mess with eyeballing a new camera placement.
Any solutions?
Rich Ramazinski
Re: pixel aspect ratio - SD to HD
on Apr 23, 2008 at 12:24:54 am
Hey all-
forgot to post the solution;
under the main camera window (or persp window), go to
View>Camera Settings>
and change "Horizontal" on the drop-down to "Vertical"
there's a similar setting in the Camera's attributes, but it doesn't seem to affect the aspect ratio change.
© 2018 All Rights Reserved
