Referencing and Cycling Problem
COW Forums : Autodesk Maya
on Oct 2, 2007 at 1:25:15 am
I built a rig for a quadraped (a rat) and now I'm trying to animate the walk cycle. If I cycle with offest in the original file, there are no problems. However, if a create a new file, reference my rat file (ma format, tried mb as well) and then try to cycle with offset, I get the error message: "Warning: One or more attributes with referenced or procedural animation were not modified." The part that isn't being cycled is the HeelControl.Roll for all 4 legs, everything else gets cycled (i.e., leg control translation, pelvis translation, joint rotations, etc.). For the referencing options, I am using the defaults except for Name Clash Options which I have set to Resolve all nodes with this string: rat.
I'm using a roll attribute to set the roll of the feet (as per the Learning Maya 8 book). It is a set driven key, I set the roll and it sets the foot and heel joint rotations for me. If I delete the roll attribute, then referencing and cycling work fine.
Any suggestions would be greatly appreciated, this has been driving me nuts for 4 days now!
© 2018 All Rights Reserved
