bad topology and ugo models
COW Forums : Autodesk Maya
Desrever
on Sep 27, 2007 at 2:23:05 pm
I'm looking for modeling tutorials which show how to correct bad topology, and improve the look of renders. I seem to have problems where I'll have what looks like a decent model in the viewport but when rendered, no matter how high the render globals are set and how many time I use poly smooth, my model looks pixelated.
thanks
Chad Briggs
Re: bad topology and ugo models
on Sep 27, 2007 at 3:23:04 pm
Pixelated? That usually points to bad sampling in the render or a low rez texture. Can you post a sample? May not be the geomentry.
-chad
Desrever
on Sep 27, 2007 at 8:36:30 pm
It's weird, I just rendered out a 1k frame to post, and it looked nasty in the render window, but when I saved it out as a tiff or jpeg, the crunchy edges are gone. Is it something in my render settings that I inadvertently changed? Possibly an interlacing or aspect ratio issue?
Chad Briggs
on Sep 28, 2007 at 12:03:52 am
ahhhh. thats the scaling in the render view :) When a image isn't shown at 1:1 in the renderview, it doesn't alias the scaling of it. Once you render, click on the little 1:1 button in the render window and it should look fine.
-chad
Desrever
on Sep 28, 2007 at 12:36:58 pm
No it's not that it's scaled up. I took a screen grab from an old tutorial that shows the problem.
Sorry for the noob question but how do I post a screenshot for you to check out?
Chad Briggs
on Sep 28, 2007 at 1:40:19 pm
you have to have your own method of posting images, the COW wont host them for you. There are many solutions tho. One is http://imageshack.us/
hope that helps
