glRender command only works once--why??
COW Forums : Autodesk Maya
Steve Sayer
on Sep 10, 2007 at 5:21:32 pm
Hello, folks. Any scripting gurus out there able to shed some light on this?
Rendering a sequence with the Hardware Render Buffer can be done by employing the glRender command. But I would like to render several sequences in a row automatically--seems like a trivial task, but I'm unable to get the HRB to render more than once per script.
I've typed the command twice--it only executes once. I've put it in a 'for' loop--it only executes once. I've tried using 'eval' and `` syntax, and even tried putting the command in a separate procedure and then calling that procedure twice--it only executes once!!
This is breaking my brain. Anyone have any ideas?
Thanks in advance,
-Steve
