Mental Ray Newbie Question: Memory/Performance
COW Forums : Autodesk Maya
Thomas Rydberg
on Sep 6, 2007 at 1:59:55 pm
Hi folks,
I just began using MR within the last week or so and was able to render out my scene in a fairly high resolution 9"x9"x300dpi. Anyway, now I'm being asked to make a poster-sized hi-res rendering of this scene so I need to bump up the size to about 30"x30"x300dpi. When I tried rendering at this size, it failed. I am using a couple of Targa texture maps in the file which I'm not sure that MR likes.
I'm running Maya 8.5 on Windows XP with 2.4 GHz processor, 2 GB RAM and 80 GB of free hard disk space.
I am buying some Mental Ray tutorials (which I haven't received yet) but in the meantime, can anyone point me in a good direction on this?
Thank you,
- Tom
Here's the maya rendering log:
9/4/2007
mental ray for Maya 8.5
mental ray: version 3.5.6.7, 22 Nov 2006, revision 19663
mental ray: mental ray for Maya - startup done
File read in 0 seconds.
Result: C:/3D Models/Elite/scenes/expressBrochure18__3980.mb
mental ray: got 2 satellite CPUs.
Warning: (Mayatomr.Scene) : mentalrayIbl1: light not found for light linking, ignored
Warning: (Mayatomr.Scene) : directConnect_directConnect1|polySurfaceShape: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : directConnect_directConnect18|polySurfaceShape: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_511004_001_6|body: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_511004_001_5|body__2: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : T11002_XXX_2|body__3: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : T11020_008_1|body__4: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__5: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__6: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__7: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__8: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__72: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__73: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__74: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__75: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__76: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__77: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__78: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__79: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_542746_002_1|body__80: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__81: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__97: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_542954_001_2|body__98: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__99: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__100: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__101: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__102: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__103: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__104: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__105: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__145: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__146: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__147: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__148: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__149: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__150: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__151: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__152: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__153: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__154: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_542955_001_1|body__155: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__156: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__157: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__158: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__183: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__184: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__185: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_9|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_9|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : Express_a_7000xx_xxxAssyExpress_SLDASM|a_700015_003_1|assembly|a_534112_XXX_8|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : Express_a_7000xx_xxxAssyExpress_SLDASM|a_700015_003_1|assembly|a_534112_XXX_8|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_7|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_7|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_6|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_6|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__194: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_5|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_5|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_4|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_4|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_3|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_3|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_1|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_534112_XXX_1|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__203: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__214: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : Express_a_7000xx_xxxAssyExpress_SLDASM|a_543030_001_1|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__1: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : clip1b|polySurfaceShape2: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : polySurfaceShape1: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : polySurfaceShape3: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : Express_a_7000xx_xxxAssyExpress_SLDASM|a_543030_001_1|part|body2|body__2: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__218: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__219: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__220: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__239: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__240: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__241: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_700049_001_1|assembly|a_535276_001_1|assembly|a_535276_xxx_1|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body3|body__3: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_700049_001_1|assembly|a_535276_001_1|assembly|a_535276_xxx_1|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : face__1: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : face__2: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : face__3: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : face__4: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : face__5: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__250: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_700049_001_1|assembly|a_535276_xxx_1|part|body|body__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body4|body__4: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : a_700049_001_1|assembly|a_535276_xxx_1|part|face|face__: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : face__6: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : face__7: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : face__8: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__273: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__274: empty UV set map1 detected, ignored
Warning: (Mayatomr.Scene) : body__275: empty UV set map1 detected, ignored
RCFG 0.4 warn 542002: angle between normal and geometry normal > 90 degrees
RC 0.2 error 081001: failed to create frame buffer 0: C:DOCUME~1tom-rLOCALS~1Temp/fb000.1.928 (Not enough storage is available to process this command.)
RC 0.2 error 081001: failed to create frame buffer 12: C:DOCUME~1tom-rLOCALS~1Temp/fb012.2.928 (Not enough storage is available to process this command.)
IMG 0.2 error 101003: : can't create file
Error: (mental ray) : : can't create file
mental ray: out of memory
MEM 0.2 fatal 031008: can't allocate 565108000 bytes.
Thomas Rydberg
Re: Mental Ray Newbie Question: Memory/Performance
on Sep 10, 2007 at 8:18:45 pm
Looks like I found a workaround that'll work. I'm using mr_tile_render 1.0.0 to break up the high-res rendering into 64 smaller tiles (8x8) and then using a batch command to call the free imagemagick software to stitch it back together. It's a good idea to try this out with a low-res render first, just to make sure you got it working.
http://www.highend3d.com/maya/downloads/mel_scripts/rendering/mental_ray/37...
Cool!
- Tom
