Animate>Create Motion Trail to a curve?
COW Forums : Autodesk Maya
Pyro
by
on Aug 24, 2007 at 3:40:09 pm
Is there a way to have Animate>Create Motion Trail output a single NURBS curve that connects the output points?
I looked at the nodes created by this command, and it included an ikSC solver. What use do you folks make of Create Motion Trail?
I want to put this command to uses for which it may not have been designed; simply outputting a very useful 3 degree curve for animating, modeling, etc.
There used to be a script on another site that output a curve from an attached point on surface a few years ago that did precisely what I'm looking for. Since, then the script may have been incorporated into Maya.
Any help would be greatly appreciated. Thanks!
Pyro
Re: Animate>Create Motion Trail to a curve?
by
on Aug 27, 2007 at 7:15:52 pm
Well, here's a multi step way to do it. We will develop a script to handle this more quickly.
Create an animated swwep with a a single span curve. Pick an isoparm from the resulting surface and duplicate surface curve. Done.
