"use background" shader / mental ray
COW Forums : Autodesk Maya
jo_graphix
on Aug 22, 2007 at 5:28:14 pm
hello!
i am rendering an object in mental ray and i need an alpha channel for shadows.
seems that maya
"use background" shader is not fully compatible with mental ray,(some bugs appear in alpha channel and not when i use maya renderer)
is there any mental ray shaders like maya "use background" shader????
my render is visible here:
http://test.graphixmotion.com/bureau_v1.9b_cam_3.jpg
thanks in advance for any help.
jo_graphix
http://www.graphixmotion.com
Chad Briggs
Re: "use background" shader / mental ray
on Aug 24, 2007 at 7:31:40 pm
what kind of artifacts are you seeing? I've used the usebg shader with MR tons and never had any problems?
chad
jo_graphix
on Aug 26, 2007 at 7:47:18 am
i made an simple image to show you the problem i have.
rendered with mental ray (maya 7 or 8.5 os x)
in both version same alpha problem appear on the left of the alpha image.
(somebody told me to use maya renderer but it produces less quality area shadows)
so i would prefer to find pro solution using mental ray.
example image of the problem:
http://test.graphixmotion.com/use_background.jpg
image where i need to catch shadows on alpha channel:
