Jelly-like material/Shader?
COW Forums : Autodesk Maya
Brian Dugan
on Jul 25, 2007 at 11:22:17 pm
Anyone know a good plan on how to create a shader for a
Semi-translucent liquid pill/capsule?
Brian
iannorthrop
Re: Jelly-like material/Shader?
on Aug 7, 2007 at 8:30:09 pm
I'm certainly unexperienced in this as well, but I've read up a bit on sub-surface scattering and I think that with the right shader and this mental ray rendering attribute, you should get the results that you're looking for.
Try researching subsurface scattering and hopefully someone else with more experience will be able to verify/elaborate on this method.
Hope this helps.
ian
