Audio Framerate?
COW Forums : Autodesk Maya
zenozeno
Audio Framerate?
on Jul 20, 2007 at 8:02:07 pm
Is there a way to adjust imported audio framerate? Audio imported into maya seems to default to a playback framerate of 24fps . . . Difficult to sync animation at 30fps to an audio track playing at 24fps . . .
Audio by default runs at 29.97, no?
Chad Briggs
Re: Audio Framerate?
on Jul 21, 2007 at 2:15:57 pm
I think you might be getting some terms confused, audio doesn't play back at a "frame rate" so to speak. In other words, if you are animating at 30 frames per sec or 24 fps, one sec of audio will sync up to one sec, no matter what the frame rate. Maybe you don't have the playback speed in maya set correctly so thats why you don't think the audio is lining up? Look at the preferences under settings, you can change the playback speed.
chad
