gravity isn't working....
COW Forums : Autodesk Maya
Justin Rank
on Jul 17, 2007 at 12:57:10 am
Ugh....
I've selected my object, then went to fields>gravity, but it's not doing what it's supposed to do. I'm probably missing something very simple here....any clues?
FWIW, the animation is just coins falling onto a table. They're all set up as rigid bodies, but when I add gravity to the coins, they just sit there...
Steve Sayer
Re: gravity isn't working....
on Jul 17, 2007 at 1:34:16 pm
Here are two troubleshooting steps:
1. Make sure the 'active' attribute of the rigid bodies is set to 'on'.
2. Make sure the gravity field isn't limited by Attenuation, Max Distance, or a volume shape.
Hope one of those helps.
-Steve
