Tweaking shaders
COW Forums : Autodesk Maya
SSGGMM
Tweaking shaders
on Jun 27, 2007 at 2:42:05 pm
I have a poly object with a shader on it (who doesn't). Can I adjust the shader on a per-face basis? Like adjusting the ambient colour, but on THAT face only.
Thanks - S.
Steve Sayer
Re: Tweaking shaders
on Jun 27, 2007 at 3:09:07 pm
Yes, by using UV mapping and controlling your texture.
Say you want one face to be black and the others white. You can map a 'checker' texture to the object, and drag the UVs for all other faces into a black region of that texture, while dragging the UV for that single face in the white area.
Note that you can also assign a completely different shader to one or more faces on your object.
-Steve
