How can i render an animation in maya 8.0
COW Forums : Autodesk Maya
CreativeGuy
on May 31, 2007 at 2:33:57 pm
My tutorial talks about a switch in Render Globals, but i cant find that one. What should i do?
GranitW
Re: How can i render an animation in maya 8.0
on Jun 2, 2007 at 4:10:14 am
You first use the common render settings. Switch the "frame/Animation ext:" popup menu to a multi frame naming formatt(exp: name.#.ext). Then below this put the start and end frames, select the camera, then go to the "rendering menubar > Render > Batch Render". Maya will then open up an exterior application that starts to automaticly render the frames you had selected in the "common render settings".
Video Specialist
Apple Developer
Owner of GranitWorks
