Menus disappeared
COW Forums : Autodesk Maya
SSGGMM
Menus disappeared
on May 29, 2007 at 4:20:58 pm
Bit of a snag here. I lost control of my fingers for a moment, hit something I shouldn't have, and now a row of menues has disappeared. I'm talking about those pulldown menus that noramlly lie atop the perspective and orthographic views. I've grown quite fond of them and would like to get them back. They're not in the UI elements, nor are they in the heads up display. I can't even locate the right reset button.
Please advise. Thanks in advance - S.
Glenn Moore
Re: Menus disappeared
on May 30, 2007 at 4:22:35 am
I looked for a command for that and couldn't find one either. There may be one but what you could do is delete your Preferences folder. I believe that gets you back to the basic, initial settings. If you made any specific layout changes, you'd have to re-do those. Someone else may have a better solution.
brooklyn
on May 30, 2007 at 7:17:44 am
See if this works:
1. In the viewport press the SPACEBAR to bring up the hotbox.
2. Navigate to the right of the hotbox to where it says "Hotbox Controls".
3. Go down to the bottom where it says "Window Options" and make sure "Show Pane Menubars" is checked.
Or Windows -> Settings/Prefrences -> Prefrences -> Catergories Interface , make sure "Show menubar" is checked for in panels.
SSGGMM
on May 31, 2007 at 2:30:02 pm
That's the one! Thanks.
S.
