motion path + air field
COW Forums : Autodesk Maya
jo_graphix
on May 18, 2007 at 9:30:22 am
hello!
i am animating letters using motion paths.
each letter has his motion path and i would like near the end of the motion paths i want them being affected by maya air field to push all letters up randomly.
is this possible to use motion path + air field...together?
i know how to use motion path and air field separatly.
thanks for any information and help.
project is visible here: 3.8mb movie
http://test.graphixmotion.com/roses_small.mov
thanks.
R303LX
Re: motion path + air field
on May 18, 2007 at 9:34:59 am
You could group your object travveling on the motion path to itself.
The let the group transform node travel the motion path. And your object underneath being affected by the air.
R303LX
on May 18, 2007 at 9:42:44 am
oh! and ofcource key the rigidbody.active attribute to switch between the motion path and the airfield influence.
This is a quick and dirty way to do it by the way.
I would use either particle and goals or constraint nodes and the fade between the solutions.
jo_graphix
on May 18, 2007 at 10:51:40 am
sorry but i understand nothing. i am maybe to beginner...
if my letters are attached to a motion path...
how i can manage after this step, to affect them by a air field???
please help me more in details if you can.
thanks
R303LX
on May 18, 2007 at 11:14:41 am
What version of maya do you use?
jo_graphix
on May 18, 2007 at 11:15:30 am
maya 7
jo_graphix
on May 18, 2007 at 11:15:08 am
BIG THANKS MAN! your solution is working! :-)
R303LX
on May 18, 2007 at 11:23:10 am
No problem...
I recomend that you look into grouping and understanding mayas hierarchy stucture. That would help you here in the beginning.
