image plane render
COW Forums : Autodesk Maya
velocity
image plane render
on May 14, 2007 at 7:30:53 am
Hi... So i have a scene with a matte painted background set up on an image plane on camera1, which i need to render with camera2, and yet have the image plane render as well. But only when i render with camera1 does the image plane image show in the render..
Is there a way to render the image plane linked to camera1, with camera2?
thanks alot...
Chad Briggs
Re: image plane render
on May 14, 2007 at 1:15:31 pm
Probably the simplest way would be to create an image plane on both cameras, assign the same BG image to both? Does that not work?
-Chad
R303LX
on May 18, 2007 at 9:52:43 am
1. Create camera1
2. Create camera2
3. In the attribute editor -> camera -> enviroment: Create imagePlane1
4. Select camera1 and camera2
5. window -> hypergraf: Show input output connections
6. In the hypergraf ctrl+mmb-drag from imagePlane1 to cameraShape2
7. Finished
R303LX
on May 18, 2007 at 9:56:10 am
"3. In the attribute editor -> camera1 -> enviroment: Create imagePlane1"
Create only imagePlane for camera1
And remember to set the "far clip plane" value on camera2 acording to camera1
