photons using mental ray
COW Forums : Autodesk Maya
cowcowcowcow
Hopkins
on May 11, 2007 at 1:56:31 pm
Hello,
I am starting learning mental ray. The first problem I have is when rendering with global illumination I see the circles of the photons.
Could you please tell me what are the values to adjust in order to blend all those circles?
Thanks a lot,
Hopkins
accpph
Re: photons using mental ray
on May 14, 2007 at 12:20:01 am
Well that's a bit tricky. there are no set numbers. You'll have to play a bit. If you see the photons there but they look like dots or circles, first decide if you have enough. If you do, fine. If not add more--realize that when using global illumination it is quite regular to have LOTS. Then increase radius until the circles start to overlap and blend; the splotchiness should start to go away. You can and should increase accuracy as you go as well, but that will only solve how accurate a given area's sampling will be.
Hope that helped,
ACC
Hopkins
on May 14, 2007 at 1:09:31 am
Thanks a lot. I'll try that.
Hopkins.
