Animating Bars
COW Forums : Autodesk Maya
Jonathan Le
Animating Bars
on May 5, 2007 at 3:49:04 pm
I am trying to animate the growth of a poly-cube which branches off at 90 degree angles at specified points in time. I am extruding a square along a curve as my staring point. I have the extrude animating well but I'm not having too much luck with the corners as they always crease and I need them to be sharp. Could someone point me the right direction?
Jon
mYthprod
Re: Animating Bars
on May 16, 2007 at 7:29:25 pm
Can you break up the curve you're using to animate along into several pieces and start a new extruded square at each 90degree corner?
- MythProd
(John David Hutton)
_________________________________________
Digital Effects Artist, Support Technician
Kansas City, Kansas - United States
