maya playblasts dropframe
COW Forums : Autodesk Maya
on Apr 24, 2007 at 3:27:09 pm
Hello All.
I have a situation that could use some major addressing. I work in a mixed platform environment that uses PCs for creating 3d content (Maya) and FCP for editing.
When I playblast an animation from Maya with the render globals set at 24 fps and output type as AVI, I get a standard windows AVI file that can be directly read by FCP.
(AVI is the only format available that doesn't use frames)
Here's the problem. Final Cut Pro reads that 24fps avi as 23.98 fps. (Drop frame). As a result, most of my renderings are trunkated by one frame. The only solution to this problem is to either:
1. Output individual frames from Maya rather than an AVI and import those frames as an image sequence in QTpro and then export out a true 24fps .mov file.
2. Load the playblasted AVI file into QTpro on the PC and then resave the file as a self contained movie rather than exporting it.
For some particular reason, any .mov file exported from the PC can not be read directly into FCP. A self contained movie works, but nothing else. What gets strange is the same file, though not readable in FCP, is readable in QT and at non drop frame.
Sounds confusing? Yes. But I've replicated the problem on every computer I've used.
I'd like to retain the avi compatibility because:
1. Animators can output AVIs directly from Maya on their PC.
2. I don't want to deal with uncompressed frames and large numbers of files.
Any ideas?
Re: maya playblasts dropframe
on Apr 27, 2007 at 8:56:27 am
I don't know if this will work, but open up your playblast options - select "image viewer" as your viewer and select "save to file" at the bottom.
Click playblast. It'll make you a preview and save a copy of the frames to your images folder in your project folder.
Then use After effects to import the images as a sequence. In AE, select file interpret footage (ctrl +f) and set your frame rate you want.
Then make a composition, drag the sequence and render it as a QT movie, NOT avi.
FCP supports avi, but I personally have better workflow/results with QT movie.
Hope this helps.
© 2018 All Rights Reserved
