URGENT!!! need to export a movie out of maya HELP!!!!!!!
COW Forums : Autodesk Maya
Diccon Mayfield
on Apr 18, 2007 at 10:34:08 am
right this may sound stupid but i cant work out for the life of me how to simply export a movie from maya like a quicktime etc etc im on maya 8 on osx......i just want to make a movie....simple
thanks
JamesPorter
Re: URGENT!!! need to export a movie out of maya HELP!!!!!!!
on Apr 18, 2007 at 4:32:15 pm
You need to export your animation as a series of images then composit them in something like after effects - then export it as a QT movie.
or go to http://forum.simplymaya.com/showthread.php?s=&threadid=10281 for more information.
Hope this helps
James
Diccon Mayfield
on Apr 19, 2007 at 2:44:29 pm
cheers mate helped me out a treat
D
Guindi
on May 7, 2007 at 4:11:43 pm
Ok, I do this every day.
In your render setting window, under the common tab. scroll the Image format to quicktime movie. make sure you include your start frame and End frame.
That's it, Batch render and your quicktime movie will be in your image folder in your project.
this works for maya software render.
In my Maya 7, mental ray would not render quicktime, you do it in two step.
If you have alpha then use maya IFF or PNG or PSD. the open the sequence in Shake or Motion then save to quick time movie.
any compositing software would do.
