Hotkey editor
COW Forums : Autodesk Maya
SSGGMM
Hotkey editor
on Apr 17, 2007 at 1:13:15 am
Is there any way to assign hotkeys to rotation, translate and scale? I don't mean toggling the tools, but rather "arrow right" rotates your selection +0.5, type of thing. The hotkey editor doesn't appear to go into such specifics. Or does it?
brooklyn
Re: Hotkey editor
on Apr 17, 2007 at 7:04:38 am
Sure you can.
In the hotkey editor pick the category you want it under then click on "new", give it a name and a description, then add any mel command you want.
In your example the mel command would be:
rotate -r -os 0 0.5 0 ;
if you want your object to rotate by .5 of a degree (which of course isn't much) on the y axis.
I don't know of a way to assign it to the arrow keys but you could always use the <> keys.
I think this is what you want, if not let me know.
SSGGMM
Re: Hotkey editor
on Apr 17, 2007 at 9:53:17 pm
That's precisely what I was looking for. Thanks so much.
S.
Steve Sayer
Re: Hotkey editor
on Apr 17, 2007 at 11:09:50 pm
[brooklyn] "I don't know of a way to assign it to the arrow keys..."
No problem there either. In the hotkey editor, notice that there's a dropdown menu next to the text field in the 'Assign Key' section. That lets you select a list of keys that don't register properly in the text box, including arrow keys, function keys, and navigation keys (Pg Up/Dn, Home, etc.).
-Steve
