poly slice?
COW Forums : Autodesk Maya
velocity
poly slice?
on Apr 12, 2007 at 2:56:54 am
Hi! I have a flat polygon that i drew freehand, and it is to be animated with a skeleton. Sooo, i need to turn it from one face into a complex mesh so it will bend as it should.
Is there a way to do this with out just cutting a thousand times with cut faces? smooth wont work....
thanks..
accpph
Re: poly slice?
on Apr 12, 2007 at 3:42:36 pm
Not sure I understand the problem; but in theory you could use the insert edge loop tool set to multiple insertions...
