Image sequence loop
COW Forums : Autodesk Maya
SSGGMM
Image sequence loop
on Mar 31, 2007 at 4:19:31 pm
My camera wants to continue animating after the image sequence has ended. In the name of the good lord, how do you stop the image sequence from looping? Somebody, please, make it stop.
Chad Briggs
Re: Image sequence loop
on Mar 31, 2007 at 5:42:55 pm
Are you talking about the image sequnce on the camera image plane? Or just maya looping when it hits the end of the time slider?
chad
SSGGMM
on Mar 31, 2007 at 6:14:50 pm
Camera image plane.
I fix it by setting a key on the image plane's alpha key, at zero, making it dissappear. But I'd still like to know how to stop the looping.
Chad Briggs
on Apr 1, 2007 at 4:46:44 pm
Weird, i've never known the image plane to loop. Generally by default when you enable the image plane, it puts a expression in the field to make the image plane frame # sync up with the frame number on the time slider. So it should never loop. If you've manually set keys (by breaking the expression), it still shouldn't loop, unless you've selected the curve in the graph editor and told it to. I guess that would be the first thing i would check, is the graph editor and see if you've got your curve set to loop in post-infinity.
chad
