Someone help confirm a bug in Maya 7/8
COW Forums : Autodesk Maya
Steve Sayer
on Mar 20, 2007 at 3:39:35 pm
Hello, folks. Here are the results of two hours of banging-head-on-keyboard troubleshooting, distilled down to a dozen easy steps:
1. Create some particles.
2. Create some geometry.
3. Instance geometry to particles.
4. Render: looks fine!
5. Create a new layer.
6. Make it a reference layer.
7. Add the particle object to the reference layer.
8. Render: looks fine!
9. Add the geometry object to the reference layer.
10. Render: looks fine!
11. Add the instancer node to the reference layer.
12. Render: WRONG! Instanced geometry does not appear in the render!!
I am sure this is not intended behaviour. Can anyone confirm this in Maya 7, 8, 8.5? If so I'll holler at Autodesk.
-Steve
Steve Sayer
Just to clarify...
on Mar 20, 2007 at 3:42:35 pm
...the steps of adding the particles and the geometry to the reference layer are not necessary. I just included them to show that it is the instancer node which is the culprit, since nothing else seems to mind being on a reference layer.
Thanks for any feedback.
-Steve
