render on Fields versus on Frames for Video editing using AVID
COW Forums : Autodesk Maya
Hopkins
on Mar 15, 2007 at 12:58:26 pm
Hello,
I've always rendered frames in Maya with motion blur. I am working with a new person at the moment using AVID that asks me to render on fields to avoid flickers and strobes.
I give him the frames through After Effects using the LOWER FIELD set.
Does it make sense to render on fields for video editing?
Thanks a lot,
Hopkins
Chad Briggs
Re: render on Fields versus on Frames for Video editing using AVID
on Mar 15, 2007 at 4:49:53 pm
Hopkins-
it's an aesthetic thing really. If you want the smoothest, flicker free movement possible, then yes you need fields. However, this tends to give animation a "video look". Sometimes this is fine (like in some motion graphics) other times you want to make it more surreal (like 3d animation with characters), so the strobe/jerkyness is fine. Easiest way to get fields out of maya (and the best quality) is to render/animate at 60fps, then compress it in post to 29.97. (or if you are doing pal, redner at 50fps, then take it down to 25fps).
hope this helps
Chad
Hopkins
on Mar 15, 2007 at 7:44:41 pm
thank you very much,
Hopkins
