modeling :: adding strcture
COW Forums : Autodesk Maya
on Mar 14, 2007 at 3:10:45 am
basically i want to know if there is a simple way to apply a structure system to an organic surface
to have an effect such as this:
and... which surface will be best for that (nurbs, polygons, or subdivision), if it makes a difference...
Steve Sayer
Re: modeling :: adding strcture
on Mar 15, 2007 at 12:24:56 am
This process of creating a curved surface out of straight lines is exactly the process used in creating 3D models. If you create a rough polygonal shell of your surface, then smooth it and triangulate it, you will obtain an almost identical effect. You can then render it in wireframe, or use a script to extrude surfaces along all of its individual edges, etc.
© 2018 All Rights Reserved
